Rear Camber Toe adjusters with Rotary slide bearings
Pete M
Post by Pete M »
Newbie here be gentle
Wondered if anyone has tried using the Ireland Engineering camber toe adjusters with E32 rotary slide bearings installed in the rear trailing arms
My concern is that as the name suggests the rotary slide bearings only rotate and slide so would they accommodate the slight misalignment caused when adjusting camber toe
I've also seen a video posted on the forum of the Pitman Arm, toe link in action showing that as the trailing arm moves the bushes allow slight laterally movement, would the adjusters cause a binding effect again when slightly misaligned
Many thanks
Peter
They work fine together. The E34 M5 had slotted toe adjusters built into the rear subframe from the factory, and also used the bearings instead of the bushings. I have this setup on my wagon now.
Pete M
Post by Pete M »
Thanks for the instant and confident reply
I knew the M5 used the bearings but wasn't aware of the slotted adjusters
Many thanks
Peter
Frybrid 524td
Post by Frybrid 524td »
I have a set of rotary bearings with some mangled boots if anyone is interested. They are unused but you'll need to get boots off of something else.
I'll take those!
