Newbie here be gentle
Wondered if anyone has tried using the Ireland Engineering camber toe adjusters with E32 rotary slide bearings installed in the rear trailing arms
My concern is that as the name suggests the rotary slide bearings only rotate and slide so would they accommodate the slight misalignment caused when adjusting camber toe
I've also seen a video posted on the forum of the Pitman Arm, toe link in action showing that as the trailing arm moves the bushes allow slight laterally movement, would the adjusters cause a binding effect again when slightly misaligned
Many thanks
Peter
Rear Camber Toe adjusters with Rotary slide bearings
Frybrid 524td
