Stainless steel brake lines, big brake conversion.
purchased an 8" sub to make an under seat enclosure thanks to the thread on here, got my diff rebuilt with all new seals & bearings, also a new crankcase breather hose.
Rebuilt my 43 year old heater valve. Diaphragm was hard as bakelite and didn't want to come out. Also my 10 year old Wahler Thermostat was sticky and lazy and got replaced. I dumped it in hot water and remained shut for 10-20 seconds (i looked away and then found it fully open). The new one opened instantly.
Got my M535i out of the garage for the first time this year, and the leaves on the trees are finally popping out. Two sure signs spring is here.
Got my windshield wiper fluid sprayers working. Ordered new hood insulation retaining screws.
^^^ Isn't that mural missing two wolves?
Replaced all my sparkplugs today, although the old ones looked super good!
austin8753
installed some extra spring pads in the rear of my m5 a few weeks ago, to attempt to correct the reverse rake. can't wait to change out the Spax springs for something else.
it's currently my only daily drivable car while the e39 is off to the body shop. been a long time since i've regularly driven it so i'm glad to bond with it again.
I cleaned my 524td up a bit today. Installed new oem floor mats and new roundels on the hood and trunk. (The old hood roundel is better quality btw).
Here is what an original full size spare looks like. 1984 date code. Made in west Germany.
I’m restoring this 1984 524td. It had a lot of paint fade on the roof and trunk. No clear coat. In an effort to try to save the original paint I decided I’m going to clear coat it. Today I restored all the black trim and finished the 1st coat and will be applying a second coat of clear tomorrow and then ceramic the following day. I also finished refinishing an oem early 80’s e28 Decklid spoiler, so that will be going on once I’m done with the paint restore. I’m very pleased with the results thus far.
Looks great!!
No clear coat from the factory? That's a huge win. What color is it, it looks like Burgundrot, which on the ones I've seen does have clearcoat.
Looks good whatever.
Yes it is Burgundrot, which has factory clear coat. But the clear was chipping in areas. The roof and trunk were especially bad with paint fading and no clear. So I wet sanded and applied a coat of clear and then wet sanded and applied another coat of clear. In a few days I’m going to wet sand again and ceramic coat. Most people would have gotten a paint job. My goal was to try to preserve and keep original paint. So I decided to redo the clear coat and keep my fingers crossed that I bring it back to life. Still need to touch up some areas with touch up paint before doing a ceramic coat. But so far I’m pleased with the results. The car is presentable now, less than 400 in products and several hours of my time saved me 5k on a paint job and more importantly, the car retains its original paint.
Actually I did something like this 10 years ago and it came out pretty well. It looked good when I was done. Not as good as yours looks, which is great, but good. And I thought I was the only one crazy enough to try to reclear something! viewtopic.php?f=3&t=131715328dabi wrote: May 21, 2025 1:52 AMMike W." wrote: May 21, 2025 1:23 AM
No clear coat from the factory? That's a huge win. What color is it, it looks like Burgundyrot, which on the ones I've seen does have clearcoat.
Mike W." wrote: May 21, 2025 12:43 PMActually I did something like this 10 years ago and it came out pretty well. It looked good when I was done. Not as good as yours looks, which is great, but good. And I thought I was the only one crazy enough to try to reclear something! viewtopic.php?f=3&t=131715328dabi wrote: May 21, 2025 1:52 AMYes it is Burgundrot, which has factory clear coat. But the clear was chipping in areas. The roof and trunk were especially bad with paint fading and no clear. So I wet sanded and applied a coat of clear and then wet sanded and applied another coat of clear. In a few days I’m going to wet sand again and ceramic coat. Most people would have gotten a paint job. My goal was to try to preserve and keep original paint. So I decided to redo the clear coat and keep my fingers crossed that I bring it back to life. Still need to touch up some areas with touch up paint before doing a ceramic coat. But so far I’m pleased with the results. The car is presentable now, less than 400 in products and several hours of my time saved me 5k on a paint job and more importantly, the car retains its original paint.
That’s actually really good. And a great write up.
Reglued all my detached door seals and door felts. Not a "hard" job at all and correcting something that bothers me every time I drive the car.
Also installed a new fan clutch and re-installed my fan shroud.
Slowly chipping away at all the little things.
Put my drivetrain back in…again. 3rd time with this car. Mods this time… 10.5:1 Ross pistons in the M90 block bored to 94mm, improved head porting (b34 head/47/39 valves with dual race springs, 290 head and rocker locks) , mated to ported b35 intake; new engine mounts, trans mounts, giubo, shifter bushings, power steering hoses, oil cooler and lines, power steering cooler and reservoir, and some other random bits.
Car has 3.73 LSD, Megasquirt with wasted spark, Auto Solutions SSK, H&R with Bilstein setup, M5 swaybars with reinforcements, E32 BBK and a whole bunch of other stuff. Can’t wait to get it back on the dyno for a proper tune with the new pistons.
Swapped a side mirrors non-working motor with one that works. Now I can adjust my mirror!!
Changed my voltage regulator. Wow.... It was way overdue.
What a difference! All the little electrical gremlins that have been bugging me are gone.
- No more stumbling at idle.
- No more having to blip the throttle to 'wake up' the alternator after starting.
- System voltage no longer dips when stopped at red lights.
- There is now a difference between the "slow" and "slightly less slow" wiper speeds.
That just inspired me to replace mine. I've had a new voltage regulator just sitting around waiting for the day i "need" it and realized better to just check and replace before that day comes and while I probably still have some life left. I definitely have noticed a higher voltage (upper 13's and low 14's) on the cigarette voltmeter where as before it was often in the low 13's upper 12's.
willyv124 wrote: Aug 05, 2025 1:14 PM That just inspired me to replace mine. I've had a new voltage regulator just sitting around waiting for the day i "need" it and realized better to just check and replace before that day comes and while I probably still have some life left. I definitely have noticed a higher voltage (upper 13's and low 14's) on the cigarette voltmeter where as before it was often in the low 13's upper 12's.
Just curious on what voltage regulator brand are you guys bought???...seems to me all stuff are chinese today...maybe not bad stuff, but.....
Glad to hear it! I wish Id thought to do mine sooner.
Finally got the AC working, changed the compressor, drier and expansion valve. I also changed the center support bearing, seal to the transmission, shifter bushing and guibo. Next thing is changing the springs to HR and some sport bilstiens.
Theres a guy who rebuilts the AC compressors in Upland, California
AUTO AC COMPRESSORS
1070 W.9TH ST. UNIT B
UPLAND,CA
909-615-0898
RAFAEL IS THE OWNER
IN CASE ANYONE NEEDS TO REBULD THEIR AC COMPRESSOR
AUTO AC COMPRESSORS
UPLAND,CA
909-615-0898
RAFAEL IS THE OWNER
