Anyone have a good source for S38 tools such as the valve adjustment tool and the Camshaft removal tools, Crank, etc...
Thanks
Engine Tools
Rich in Tupelo
You just need to make sure that the shaft is coming up straight, parallel to the cam tray. Sometimes, you need to pull on an end with your hand whilst loosening nuts on the loaded end. No special tools needed, not that it'd hurt.Rich in Tupelo wrote:Camshaft tool suggestions? Or can you just loosen slightly each nut until the pressure is reduced?
As for valve adjustment, do you think you'll have the seats recut? If so, you may consider just paying a pro to do it, considering what you are likely to spend on a tool to remove the springs, and the adjustment pucks. If the pro knows BMW, they may have several pucks on hand. FYI, Honda guys do not usually undertsand, and may cut the valve stems instead...
