1988 528e full part out
located in Sacramento CA
Black exterior, beige interior
Auto trans car with some front end damage.
Engine seats and center console with power seat controls already gone.
Let me know what you're looking for.
Re: 1988 528e full part out
Does it have 3.46 diff and is it open?
I'm looking for the removable firewall panel in front of the fresh air blower. It has a rubber like coating and goes nearly the full width of the firewall. Mine is an M5, but think the part may be the same. For the life of me I cannot find the part name on RealOEM again, but it is NLA and an odd name.
Thanks
Bill
Thanks
Bill
That part is #51711917396. Showed in HVAC, heater closing panel is the Realoem nameBillL wrote: Nov 10, 2024 7:06 PM I'm looking for the removable firewall panel in front of the fresh air blower. It has a rubber like coating and goes nearly the full width of the firewall. Mine is an M5, but think the part may be the same. For the life of me I cannot find the part name on RealOEM again, but it is NLA and an odd name.
Thanks
Bill
I’m looking for a drivers side tail light, and the fan speed control switch from the backside of the hvac panel
Just checking I believe the fan control switch changed in 85. So if your car is 82-early 85 might not work.Freight wrote: Dec 30, 2024 3:14 PM I’m looking for a drivers side tail light, and the fan speed control switch from the backside of the hvac panel
Andy
I may have just pm’d you, but the car is an 86
I am out of the parting biz, sorry.
Andy
Andy
Post by Freight » Dec 30, 2024 12:14 PMI’m looking for a drivers side tail light, and the fan speed control switch from the backside of the hvac panel
___________________________________________________________________________________
I have both the tail-light and the speed control switch available.
Needing the driver’s side rear door lock assembly?
Looking for Driver side interior door handle assembly (x2) as well as pearl beige door handle bezels (trim?).
No need myself, but you might want to check. Typically auto 88 eta's came with 3.46, which is much more desirable than the earlier 2.93.
Mike W." wrote: May 08, 2025 12:55 AMNo need myself, but you might want to check. Typically auto 88 eta's came with 3.46, which is much more desirable than the earlier 2.93.
It's an auto trans car and as far as I can tell that came with the 2.93:1
Have not gotten underneath to verify.
how much for the brake reservoir cap / level sensor
Are you doing any sheet metal cuts for rust repair?
I need rear window lower corners left and right and the inner trunk latch support area.
Is it an ABS car?
All cars after 84 were abs
Andy
Andy
Oh I didn’t realize that. Maybe Canadian market was different, my ‘86 528e didn’t have ABS. No holes in the arms or front strut housings either.
I asked as I could be interested in the front sensors, if you can extract them from the strut housings
JoelTell wrote: Nov 05, 2024 5:00 PM located in Sacramento CA
Hi Joel! How does the rear windshield trim look?
I'm looking for the left and right side 'Decorative Strip 51311820624' and the top side 'Moulding Upper 51311820623' pieces.
#'s 7 and 11 here --> https://www.realoem.com/bmw/enUS/showpa ... Id=51_0241
Thank you!
Thank you!
Daily28 wrote: May 28, 2025 2:13 PMJoelTell wrote: Nov 05, 2024 5:00 PM located in Sacramento CA
Let me know what you're looking for.Hi Joel! How does the rear windshield trim look?
Thank you!
Unfortunately those pieces are entirely cracked and discolored.
lateforlunch wrote: May 21, 2025 5:52 PM Are you doing any sheet metal cuts for rust repair?
I definitely can cut parts for you. Just need to know how big a section you need.
Hi. I am looking for E28 rear window motors. Thanks
how about the muffler? Another Sacramento guy with a super eta is looking for one.
Do you happen to have the AC switch and black wire connector that it connects to?
Hello,
I am looking for two door brakes, left side front and rear... with the screws and the pin and cir-clip if possible. Front and rear seem to be different, if that helps.
Thanks! Andy
Thanks! Andy
