URO Fuel Level Sending Unit?
thrty8street
Post by thrty8street »
Does anyone have experience with a URO Fuel Level Sending Unit? The OEM unit is over $400.
https://eeuroparts.com/product/uro/16121153050
https://www.fcpeuro.com/products/bmw-fu ... 21153050-1
thrty8street
Re: URO Fuel Level Sending Unit?
Should I be the guinea pig and test this thing out?
I am planning on putting in a new in-tank fuel pump and this is one of those "while I'm in there" type of scenarios. My fuel level gauge has always been wonky so I figure this will fix it. Although, I have read that cleaning the stock fuel level unit with some alcohol will clean off some debris that may cause it to get stuck. I just want to avoid having to go back and forth chasing an issue if I can fix it on the first try.
Any suggestions?
turbodan
Post by turbodan »
It might be alright. If the price is worth a gamble, might be worth a shot. I'm sure it won't match the original in terms of quality and longevity, I've never had one fail. A good used one should be easy to come by, that's probably the best way to go unless people are trying to wring a bunch of money out of them.
LarryM
Post by LarryM »
OP: Just wondering if you tried out the URO unit, and what your experience was.
Pretty sure my fuel level sending unit has failed too, and am trying to decide which way to go: used or new replacement. As you noted, new OE ones are pricey.
austin8753
Post by austin8753 »
i'd go with a used unit before i bought a URO unit.
LarryM
Post by LarryM »
Yes, URO doesn't have a great rep. My inclination is always to go new OEM, but if I were to find a known-good used one I'd consider it.
gwb72tii
Post by gwb72tii »
LarryM wrote: Dec 12, 2024 12:43 AM Yes, URO doesn't have a great rep. My inclination is always to go new OEM, but if I were to find a known-good used one I'd consider it.
I have heard of the bad rep for URO for years, way before buying an e28. When my tii was rear ended, forcing repairs and an eventual complete resto, I had to use various URO parts as a lot of OEM parts aren’t available. I have to say I’m pretty happy with the parts, mostly things like door weatherstripping and various rubber bits. I recently bought and installed a trunk seal from URO for my e28, and it fits perfectly. Hard to imagine the factory piece would be better.
I have no reason to defend URO, other than I haven’t had issues with their parts so far.
thrty8street
LarryM wrote: Dec 11, 2024 8:06 PM OP: Just wondering if you tried out the URO unit, and what your experience was.
I did not try the URO unit. The URO unit it currently priced at 135 - I almost feel like I should take one for the team just to try it out. I will update this thread if I go this route.
Are you having issues with your fuel gauge?
LarryM
Post by LarryM »
thrty8street wrote: Dec 12, 2024 10:56 AM
Since I purchased my car over 10 years ago my fuel gauge has never registered over 3/4 full, even just after a fill up. It’s a minor annoyance but something I’ve always wanted to take care of; other work on the car took priority.
There are some used sending units on eBay with asking prices of ~$150 but in the end I’ll probably just go with new. Hopefully they aren’t being outsourced to China like some other parts are now.
austin8753
they are 100% made in China, but then again, the Continental/Siemens/VDO stuff is also all made in China today. i've ran a few of their fuel pumps over the years with no success. they work for about a year; i would imagine a fuel level sender having about the same length of longevity.
LarryM
Post by LarryM »
^^^ Thanks for pointing that out. After my experience with multiple Chinese-made heater valves and other parts over the years, no more.
I'll shop for used.
K-jetFTW
Post by K-jetFTW »
Confirmed, I installed the URO sender with a new in tank pump. Both proudly assembled in China, both work fine so far 6 months on.
The main concern for me was whether these 2 units together were going to form a good seal.  No issues so far with a full tank.
Any questions lmk.
LarryM
Post by LarryM »
Did you notice any apparent differences in quality between the  OE and URO components?
K-jetFTW
Post by K-jetFTW »
IIRC the unit itself seemed a bit lighter weight wise. Mostly I was suspicious of the new gasket, seemed less pliable. Other than that, nothing stood out.
It all went together as 2 factory units would, no seepage at the seals. It came with all needed nuts, washers, gasket. I'm expecting the el-cheapo pump itself to quit first, but for now that's ok too.
Oddly no final resolution, but there was a thread on First Fives a while ago about just replacing the wire inside the sending unit. And apparently the right wire was sourced.
https://www.firstfives.org/phpBB-3.2.1/ ... hp?p=29996
LarryM
Post by LarryM »
^^^ Too bad there were no updates on that thread. I found that wire on Amazon and I'd be willing to try repairing my existing sending unit if it actually resolves the issue.
K-jetFTW
Post by K-jetFTW »
My original sender still worked fine. However, the level of corrosion present had eaten the pot metal of the top plate to half its size, and also eaten into the dead pump. 3 of the senders mounting holes were gone, and it was sealed with orange gasket maker. Obviously all new parts were in order.
I'm glad I got it done, I figure these new parts are several degrees less dangerous. I suspect others have uncovered that type of corrosion under that trunk plate....
URO Support
Post by URO Support »
Hi everyone, we sell quite a few of Fuel Tank Sending Unit 16 14 1 152 266 annually, which is covered by our two-year, unlimited mileage warranty.  If anyone tries one and has any issues (please let us know via our website), we'll certainly be happy to get you taken care of with a warranty replacement.  Hope that helps!
Tags: 16141152266, 16121153050, 16 12 1 153 050
turbodan
Post by turbodan »
If yall are willing to stand behind your products and maintain a presence in the community, it goes a long way.  Most aftermarket suppliers give zero shits, so we certainly appreciate it.
LarryM
Post by LarryM »
Appreciate URO Support chiming in.
I had made the decision to purchase a new BMW sending unit, which arrived a few days ago. It’s made by VDO with a BMW part number on it, and I was pleasantly surprised to see it was indeed “Made in Germany”. I installed it today and well, it works. For the first time in the 10+ years I’ve owned my car, the fuel gauge registers on the “full” mark (rather than 3/4 full) after a complete fill up.
thrty8street
URO Support" wrote: Feb 03, 2025 1:25 PM Hi everyone, we sell quite a few of Fuel Tank Sending Unit 16 14 1 152 266 annually, which is covered by our two-year, unlimited mileage warranty.  If anyone tries one and has any issues (please let us know via our website), we'll certainly be happy to get you taken care of with a warranty replacement.  Hope that helps!
I just ordered this unit. I will follow up with an update after installing it.
Glenn in encinitas
Post by Glenn in encinitas »
Glad to see URO standing behind their product.  Good for them.
thrty8street
Just put the new unit in today. There is a noticeable difference in length between the two, not sure if this will affect anything, like reading empty sooner than it actually is.
URO’s website lists the oe BMW part number as interchangeable with this one.
I will report back with some feedback after driving for a few days.
Assuming the URO unit is shorter? If it's longer I doubt it will even fit in. If it's shorter the low fuel light will come on before it should and all readings are likely to be as if it was, I dunno, maybe a 14 gallon tank. Might, or might not still be ok, but it makes me arch an eyebrow.
Unless you have a euro tank in which case I have no idea.
Aldo525
Post by Aldo525 »
xxx266 is shorter than xxx050. First one is more likely e30's and xxx050 is the right one to 70 liters e28 fuel tank. My car came with the shorter xxx266 when I bought it and the fuel gauge just goes to 3/4 when full. If the user wants to see full gas gauge when the tank is full, so the xxx050 is the solution.
thrty8street
Yes, the new URO 16141152266 unit is the shorter one. Unfortunately, the issue I was experiencing, persists. Details below.
And now, I have the fuel gauge does not read all the way full after filling up. See below.
My reason for changing the sending unit is to fix the fuel gauge needle from drastically moving when going up/down a hill or accelerating. I would like an accurate reading of my gauge. Any other suggestions of how to fix this?
Aldo525
Post by Aldo525 »
thrty8street wrote: May 04, 2025 4:23 PM Yes, the new URO 16121153050 unit is the shorter one. Unfortunately, the issue I was experiencing, persists. Details below.
I think that sudden movement is the lack of some resistor or a bad one in some part of the gauge or circuit plate....not sure which one but here there are more than one electronics expert who can lead you in a solution.....
