E28 M5: Bringing it back to life (UPDATED 8/14/16)
MilanoFc
Re: E28 M5: Bringing it back to life (UPDATED 8/8/16)
Post by MilanoFc »
1st 5er wrote: I've got my OEM one setting in a box in my garage.
It was in good working order,
replaced an all aluminum one because group buy.
Holler if interested.
Thanks Sherman, I should've texted you the day I figured it was missing. I ordered one from BMW the next day in the morning and it got here yesterday. I was really trying to get an aluminum one, but it would've taken 2 wks and I did not want to but myself in that position. I plan on having the engine running today.
tschultz wrote:Love that bundle of snakes! Out of the car you actually get to see them!
Yes!, I got to admire them before the engine went in and went into hiding haha.
wkohler wrote:
1st 5er wrote:
MilanoFc wrote:... with the exception of the radiator being the only task at the moment. For some reason I thought I had mines, which I probably did, but after all these years who knows if we ended up scrapping it thinking it was for another car. So know I need to hunt one down and hope I can get it by ends week...
If it's been setting empty for any length of time, it's not a good one now unless it's resealed.
That was my worry if I had found it. My plan was to get it tested before it actually went in.
Dubs wrote:killer thread, thanks for taking so many inspiring pics.
Dubs
Thanks. I try the best I can to keep taking the pics, but since I get so into it, I tend to forget as that would require me to stop what I'm doing.
MilanoFc
Re: E28 M5: Bringing it back to life (UPDATED 8/14/16)
Post by MilanoFc »
So Saturday we worked for 12hrs straight. We got all the components on that was remaining, poured in the fluids and were getting ready for start up at around 8PM. Well we do our attempt and nothing, just cranks but no start. Check for fuel and spark and we have neither. So tired and disappointed we called it quits and went home. This is what it looked like when we left.
So today we brainstorm and well I never cleaned up the grounds of paint, so did that and also clean the relay contacts since they've been just there for 7yrs. So that is done and now we have fuel and spark! But we can't get it to start over. Well my brother looks over the ignition wires he had installed and they are on incorrect, but because I numbered them but could not remember if I had done so by the firing order or the order that I removed them. Well he figured that out and voila!! Its alive after 7 years!! Left it running for 30mins and all if well. Only issues so far is a dead Tach and the T-stat housing is seeping coolant from the joint. I can sleep with a smile! Enjot the vid!
https://youtu.be/NxUfUtTcTKQ
MilanoFc
Post by MilanoFc »
Well I'm 5 days away from the big day. Im off this week, so I'm attempting to do get it wrapped up no later than thursday so I can atleast drive the car for a day to make sure all is well. Still dealing with personal matters so I get side tracked and its stressful. This is where I stand as of tonight sorry for keeping it short. Let's see how it goes..
86GT635
Post by 86GT635 »
Go, Go, get it Inspector M5 gadget.
This whole thing is inspiring, so don't let the self-imposed stress hurt your enthusiasm. It's just a date and you have personal life events that are huge, so take a deep breath and come back at it when your mind clears maybe?
Pavel
Post by Pavel »
Congrats man, on both occasions! We got ours wrapped up almost 2 weeks ago. Stop by on the first test drive, or I will come by! ;)
Looks stunning!!!
Pavel wrote:... or I will come by! ;)
Looks stunning!!!
Holler via text, and I'll try to make it a threesome. ;)
CBREEZ
Post by CBREEZ »
Truly amazing work, especially in the amount of time!
MilanoFc
Post by MilanoFc »
CBREEZ wrote:Truly amazing work, especially in the amount of time!
Sorry for not posting any updates, but after the wedding I got busy with the home with having to furnish it and what not. We had gotten the home painted by someone but disliked the color, so for our honeymoon we painted the complete first floor in 3 days. So my D-day was Aug 27th. I had to be at Chruch at 1P.M. and I got home at 12:30 to clean it up the best I can! So I got done just in time. Still some nick nacks I have to address, but those will be done with time now. I'll post better pictures once I have them, now I'm posting the one I took at the gas station and one I got from someone that took one at the reception.
Congrats! I wasn't sure I'd like the Lapis with shadowline, but it's pretty slick! Well done. How much do those rear tires rub? :shock:
I'm digging everything but the wheels. It would look amazing with a properly fitting set.
MilanoFc
Post by MilanoFc »
wkohler wrote:Congrats! I wasn't sure I'd like the Lapis with shadowline, but it's pretty slick! Well done. How much do those rear tires rub? :shock:
Thanks! Well I adjusted the height with an empty tank and not accounting people in the back seat. Alone in the car its fine, but once we got in the back seat after the mass to the venue, the tire got murdered. So I have to redial the rear higher.
I also wanted to say thank you, because of your build thread and OcCoupe, I was able to pull this off. I work in the collision industry, but doing a restoration from the ground up is a total different beast. I studied you guys build to set up a plan before I started.
Kyle in NO wrote:I'm digging everything but the wheels. It would look amazing with a properly fitting set.
Thanks, I know the wheels are a different style and not everyones cup of tea. But I do have a set of the BBS RS211s that I will be restoring to keep the period correct look.
86GT635
Post by 86GT635 »
That's awesome, you actually did it. That's really cool and quite the accomplishment. Way to go man. Congratulations. Best wishes on your new chapter of life. You've got a lot to feel good about.
Pavel
Post by Pavel »
I am glad you were able to join on Friday at my house and finally meet up with ovide (Ivo). And I finally saw the car, despite in the dark :)
Chimi-Changa
Post by Chimi-Changa »
Been studying this thread for a while- so much good stuff in here.
Any finished product shots to show off? Also, I am looking to also do a spray in floor insulation, any feedback on how its been noise level and insulation wise?
Amazing work- Thanks for sharing
MilanoFc
Post by MilanoFc »
Chimi-Changa wrote:Been studying this thread for a while- so much good stuff in here.
Thank you. Feel free to PM me if you ever have a question, or anyone for the matter. I do not really frequent the forums since work is kicking my arse.
Believe it or not, I have yet to do a proper shoot. I have it on my list to do but sadly never get to it. Let alone I hardly have driven it since where I live they are having major road construction and I rather keep her safe. But for sure soon I will get her out and snap photos of the finished product.
As to your question for the floor insulation. On the noise level, I personally have no problem with it. IMO it is pretty quite, especially being I do not even have the stereo system done and have had no urge to do so :rofl: . I can carry a convo in the car no problem. Heat insulation wise, I can feel some heat coming from the tunnel area, but nothing drastic. I once drove it 2 hrs towards the coast and would just feel the heat at times, not that it would heat up the cabin either. But to be completely honest, I never got to drive the M5 prior to the resto or another one for that matter so I cannot compare if it was an upgrade or downgrade. Now do I regret going that route? not at all.
Sweet build! Unsure how I missed this one.
Any updates or new pictures? Will it be present at this years TexFest?
Nebraska_e28 wrote:Sweet build!
Good question since not a newlywed any longer. :laugh:
