what can i use to clean a alternator?
ChefShawn
Post by ChefShawn »
is brake cleaner a good idea?
what about that little black piece on the side that has (copper?) conectors?
i thought my alt had gone, but it turns out it was just the battery! eh :?
figured i would clean the alt while it is off
thank you
happy new year
Shawn :)
Velocewest
Post by Velocewest »
Brake cleaner is a bit too "solventy" -- can melt insulation, etc. Better to pick up a can of Electromotive electrical parts cleaner spray.
Clean the connectors with a small wire brush or some abrasive paper.
It's worth checking the voltage regulator while you're at it. Easier to replace with the alternator out.
[Edit by Velocewest on [TIME]1136495309[/TIME]]
Jay in VA
Post by Jay in VA »
I second that motion, as inexpensive as they are, throw in a new regulator.
ChefShawn
Post by ChefShawn »
thanks guys! will check soon...by the way how do i check a voltage regulator? do i need a meter? dont know if i have one....hmmm ~_~
Velocewest
You test the VR by testing the output of the alternator. I was thinking more in terms of physical condition -- like, if the brushes are pretty well worn, just slap in a new one, they're only about $20. If the Alt has more than 50k on it, just stick in a new VR. It falls into the "while you're in there" category.
If it's really dirty and oily, get a can of electric cleaner from Yardbirds (if they still have
anything in stock) and just spray away. It's meant for things like alternators, I did it to my
535i when I got it 115K ago and the alt is still going strong so it can't hurt much. It
won't hurt plastics for the most part. Brake cleaner or carb cleaner are too strong and
could melt the insulation or penetrate into the diodes.
You really need a meter, even if it's just a 5 or 10 cheapie from Harbor Freight,
something to measure voltage. Voltage regulators fail mostly just by wearing out the
brushes, which are replaceable if you are ok at soldering. Or just pick up a used one
at Pick and Pull, they're cheap up there.
Mike
ChefShawn
Post by ChefShawn »
just learning that yardbirds got bought out by home depot!
