Frybrid 524td wrote:I had to use a lot of heat and a mallet and chisel to get the old bushings out. As long as you're careful with the Sawzall, I think that is your best bet.
Did you get the welding done to the subframe?
Ok, got it done. That job was the worst I've done on this car to date. I made the e30tech.com "press" (
http://www.e30tech.com/forum/showthread.php?t=9905) which is great for all rubber bushings, but not the E28 bushings which consist of a metal bolt tube surrounded by a metal casing encased in rubber. The technique which finally worked was to take a 3/32 drill bit and carefully drill between the outer metal ring and the rubber. If you can weaken the rubber that holds the metal ring, it will be easier to get the whole bushing out.
Once doing this, I then built the press to push out the bushings. I had to heat the bushings up pretty well and I heated the TA bushing tub as well. The key was the drilling and the heat which finally allowed the bushing to come out.
These bushings are tough to get out and don't go without a fight. I'm installing AKG polyurethane bushings, so hopefully I'll never have to do this again. If I had to, I would definitely take them to a shop and have them pressed out. Here are some pics:
[/url]
