I replaced my upper and lower control arms over the weekend to attempt to fix a shimmy that I only get at the track. After replacing the upper thrust arms, I noticed that I can move it slightly in a horizontal direction. Is this normal? Has anyone needed to reinforce the mounts?
Thanks,
Andy
Thrust Arm Movement
The UTA bracket is supposed to actually clamp the UTA when the bolt is correctly tightened such that the arm center does not rotate. Normal suspension travel twists the rubber that surrounds the center.
If you read your Bentley manual you will see a routine whereby the car is sitting on the tires and weight is added to the front seat to put the arms in a rated load/ ride height position........then you tighten the center bolts to spec. A drive-over pit makes the job a cinch. Otherwise some other means of access is required.
Dick
Dick
andy535iyes
