\probably just looking for confirmation on what I already suspect
I'm unsure of any motor internals aside from a headgasket that was replaced. The PO suspected it may possibly be a hartge cam due to the H. I'm kinda doubtful. I just checked & didnt see the stamping between the cylinders as Chris mentioned, but it is stamped 3.5 if that means anything. The only other items that pointed me to think it may have a unique cam are the Hartge valve cover, headers, & gauge pod. Though that really doesnt say anything but possible inference.Minotaur wrote:Do you feel the cam is the only special Hartge item in the head? Have you considered the valve sizes? Is there any porting or polishing? What makes you think it has Hartge goods on it?
Either way, the Hartge "special cam" part numbers for the 3.5L are as follows:
Up to 8/83: 11400626
9/83 on: 11400628
I suppose you won't find a part number on the cam, but who knows. It should be a Schrick 282 interval cam, though.
Thanks for the pic, I forgot about that.wkohler wrote:The Hartge stamp in the head is on the left side, at the very top between cylinder #2 and #3.
