First had to actually tune the WOT. That took 3 runs. Then had to tune the portion of the map right off the stall. Took 3 more runs. Tried tuning the boost control all night. Couldn't stop it from spiking in 1st and 2nd gear and hitting the overboost protection. 3rd gear was a solid 180kpa. Even disconnected the boost control and ran on the spring (7psi) and accidently shifed the car into neutral at mid track (
Anyway. Made huge progress. Here is the good news.
Car is going to launch hard ever time. I am thinking 1.6x 60 foot times should be doable. Best run came with launching at 3285rpm at 7.25psi according to the datalogs. Too bad it hit the fuel cut 3 times in 1st gear and once in 2nd gear.
1.78 60ft
12.49 @ 110.49.
the 8psi run while shfting into neutral
1.84 60ft
12.94 @ 106.68
I am hoping to get to the track one more time just running on the spring at about 15psi.
Will load a video tomorrow.
Todd
