Anyone know the diameter of the stock M5 swaybars?
GaAlpinaOwner
Post by GaAlpinaOwner »
looking to beef up - maybe with either 22mm F 16mm R or
25mm F and 19mm rear.
anyone out there done this ?
any suppliers other than Suspension Techiques?
thanks
David
I believe that stock is 25mm front and 19mm rear. There are few upgrades available from that.
GaAlpinaOwner
yep just checked 25mm F and 18mm R for oem
they may not be a lot of upgrades to this.
Philo
Post by Philo »
The Dinan rear blue bar is 19mm.
OEM for the NA M5 is 25/18
Most aftermarket bars are 25/19, but since they're adjustable they can be make even stiffer than the M5 bars. Don't go full stiff on a big rear bar without reinforcing the mounting tabs though. They WILL break off.
Philo
Post by Philo »
Also, with the after market bars that have adjustment holes on the bar, you should go with adjustable links as well. On the stiffest setting the OE links are too short.
