Suspension Question
euroJeffrey
Suspension Question
Post by euroJeffrey »
Will a set of e24 coilovers that fit a M6 fit on a 88 e28 M5?
Post by C.R. Krieger »
I dunno. The chassis are identical. What do you think?
euroJeffrey
the front sturts are the same part #.
euroJeffrey wrote:the front sturts are the same part #.
Think you just answered your own question.
Scottinva
Post by Scottinva »
I think they will only work on my car, lets test to find out!
Whatdooin
Post by Whatdooin »
Rear spring perch is different on a M5
The fronts will work
CSBolger
Post by CSBolger »
[quote="Whatdooin"]Rear spring perch is different on a M5
The fronts will work[/quote
If you're referring to the SLS, it doesn't matter. The M6 setup will work just fine.
