tach sensor location 524td 86
popcorn
Post by popcorn »
where is it located, any physical adjustments and has anyone bought replacement and web site
Is your tach not working? If the car runs its probably going to be a problem in the cluster.
altus22
Post by altus22 »
Is your coolant gauge flaky too? I'd bet that some solder joints in the ecu are starting to go bad. If you have a spare, try swapping the ecu or if you're good at soldering, reflow the board. My tach doesn't work and my coolant gauge is flaky and the ECU is my next step as I've been through the cluster a dozen times.
popcorn
Post by popcorn »
cluster is new , only the odometer is not working.
tack will jump up sometime , then fall back, usually when starting off fast. but most of time nothing
Gravity Fed
Post by Gravity Fed »
id like to know how this works as well for an engine swap project
altus22
Post by altus22 »
Check the ETM for the wiring diagram. I'm pretty sure the tach signal is conditioned and read by the ECU before being sent to the cluster.
