How much does the complete motor and 5 speed trannie weigh ? Any thoughts?
I was reading up on the 535 that sold on Ebay with the LS1 motor. Someone mentioned the weight of that combo is in the 500lb range with motor/trannie.
M30B34 weighs?
The M30 weighs approximately 315 pounds.
And this from another forum:
"However, I found a couple of GM press releases that indicate the "new LS1 engine saves 65 lb. over the previous small block." The 60's -70's small block Chevies were typically ~575 lb. Like the Fords, the blocks got somewhat lighter as GM struggled with fuel economy. So maybe a more modern small block Chev would be around 560 -565 lb? Subtract the 65 lb. weight savings GM claims for the LS1 and you're right around 500 lb."
I don't know about the transmissions, but it looks like the LS1 is going to be about 185 pounds heavier than the M30.
rlomba8204
Weight vs hp
Ok, so you put the battery in the trunk, drop the LS1 in and gain 140 hp.
How much hp can you buy for 2500.00$ m30b34 (cost of used LS1/trannies)
I know these questions stir a lot emotions but let's look at this as a fun blvd curiser and not a "track" best in handling.
After all I enjoy riding around in a non specific ride that kicks the crap out of rides costing thousands more!
rlomba8204
Re: Weight vs hp
Brad (bigbronzerim) is probably pushing 350hp for less than $2500 in his turbo build, but he did all the work himself.edlocke wrote: How much hp can you buy for 2500.00$ m30b34 (cost of used LS1/trannies)
M30 engine w/o exhaust manifold + g260 tranny weight is 540lb.
http://www.mye28.com/viewtopic.php?t=67089
That may be, but being a V8, it's a shorter motor, so the weight is generally further back than with the M30.rlomba8204 wrote:ed-
If you want to go fast in a straight line, buy a traditional American muscle car. Given that the e28 is already prone to understeer, dropping another 185lbs or so (say an LSx is now 500lbs) over the front axle will make it a pig in the handling department. That's the main reason not to do this.
