Well I finally cut them out, took forever, but on the installation of the new bushings i lubed them up with soapy water and began jacking them up with a floor jack and blocks of wood, but now they seem to be stuck half way in the subframe and halfway out.
Pushing them in only jacks the car up further than my jackstands.
Some input please?
The way that I did it was to run a chain under the subframe and wrap it around my jack this way when I jacked up the chain pulled down and pushed up. Now with the chain I found that the size that is used for hitches will fit, any bigger will not fit between the subframe and the body. Good luck
