Dieselboost's 524compoundTD
DieselBoost
Post by DieselBoost »
hello again.
new project pics here.
http://irc-galleria.net/archive.php?nic ... id=2662987
i tested, how new parts fit in. not final position as you can see.
engine in pics is old "water-drinker" and im working it to get it out from car.
there is allso old exhaust manifold and inlett.
oh, i forgett, the carage is new and im very happy with it
chrism
Post by chrism »
Good job!!!
DieselBoost
this is nothing to do with diesels or even bmw:s but i love this car.
http://www.youtube.com/watch?v=cA8ouFf_NVI
DieselBoost
ok, my new tyres arrived.
rear tyres. nokian-tyres 255/40r17
front tyres. nokian-tyres 215/40r17
heh its going wild to fit those giants to my car. :shock:
i must get new rims, i i will buy keskin kt1 rims
rear 10"
front 8.5"
maybe mk2 golf rear fenders will help with those.
DieselBoost
DieselBoost
ok. yesterday i cleaned my carage and dissembled electrics from the engine, now i must only bolt off and get engine out.
DieselBoost wrote:ok, my new tyres arrived.
rear 10"
front 8.5"
What offsets will you be running?
DieselBoost
i dont know, yet. must do some measurements first
DieselBoost
ok. my intake manifold is ready,
i just modify the old one.
pictures. http://www.mye28.com/viewtopic.php?t=57130
DieselBoost
hello again.
project is in ice about 2weeks because i must keep working with couple of my new turbos.
Garrett t04/t03 hybrid turbo and Holset hx55/??? hybrid turbo.
last one will be my td:s "show turbo"
What are you doing to the injection pump?
DieselBoost
pump is going to this workshop www.ppdiesel.com
i dont know all.
what i know there is gonna be 12mm fluidhead(i dont know the english word)
and something to äähh..
this http://www.netikka.net/vepiku/viritys/PICT3727.jpg
that is only selfmaded modification in picture by some guy.
IPM
Post by IPM »
What is that a picture of?
IPM
Post by IPM »
DieselBoost wrote: new turbos.
Did U buy one of those chinese ebay turbo's?
DieselBoost
greez. project on the move..
about in 2weeks im posting a new pics about my engine finished cylhead.
DieselBoost
new gearbox and differential gear box (what is the real word)
gearbox is getrac 260(manual)
differential gear ratio is 3.15
this means speeeeeeeeeeeeeeeeed :haul:
DieselBoost
in the past, few people asked me. how large is combustion chamber of td-engine... so here is it.
http://e28-535i.com/upload/mye28.jpg
DieselBoost
surprise...
cylhead is again late.
my cylhead maker have some problems to get parts.
head is finished but valve locking (chucks? right word???) are somewhere.
DieselBoost
my cylinderhead is finally here :ohyeah:
pics comming later today...
DieselBoost
pics of cylinderhead in here....
http://e28-535i.com/upload/1_39.jpg
http://e28-535i.com/upload/2_34.jpg
better pics later...
altus22
Post by altus22 »
That is super sweet! Is that a custom casting? What are your power or torque goals?
DieselBoost
intake flows 272 in 13.5mm lift, in 13mm lift 260 and 11mm lift 228.
exhaust flows in 11mm lift 133 and 13mm lift 133.
intake valve is 38mm (stock 35mm)
exhaust valve is 34mm (stock 31mm)
these measurements are done with non turbo use sucktion flowing meter.
so in turbo use it flows much better
valves are bigger than original and exhaust seats are 2mm bigger too.
valves are stainless steel.
Alleslowbuged
Post by Alleslowbuged »
Dear Dieselboost,
looks like a nice project. I have just restart my E28 524 again.
What is your goal for hp and torque, my one has 200hp and 380Nm in the actual setup, still using a 10mm hp plunger in the injection pump. I have also work on the cylinder head but use stock valves. With your 12mm injection pump and the bigges valves you should be able to to make 250hp+.
Here are some pics from my car, i have build a similar intake like yours, but designed as dual plenum intake. Did you think about using a NA intake as basis, this should flow much better than our strange designed turbo intake. I have allready bought a NA intake, but work in my golf mk1 in the moment, so this evolution has to wait a while.
http://s702.photobucket.com/albums/ww24 ... /524%20td/
Good look for your project, i will keep my eyes here.
Here are a link with dyno run results from another E28 forum:
http://www.e28-forum.de/forum/forum_entry.php?id=219139
Best Regards
Alleslowbuged
t-race
Post by t-race »
I have a 524td too...
DieselBoost
Alleslowbuged wrote:Dear Dieselboost,
Best Regards
Alleslowbuged
i will post new pics when my head gasket and bolt operation is ready
i hope we can get over 300bhp and 600nm
Alleslowbuged
Dear Dieselboost,
huge numbers but with the 12mm plunger realistic in my eyes.
What type of headgasket will you use? I have a custom mls headgasket, from thailand, which is available in every thickness you wand. If you wand the contact, please contact me. Becuase i have send my stock gasket as template, you can bus just as a stock gasket.
I can also give you a contact for ARP bolts, if you not allready have some.
Best Regards, Alleslowbuged
I would be very happy to see 300hp in your car, would be a good goal for me.
DieselBoost
base head gasket is custom made by one local group, and those separated copper sealing rings (i dont know the english word)
and half-inch thick head bolts in block (original 11mm)
DieselBoost
having fun with couple of my friends, car is not my but our cars colour is allmost same.
http://www.youtube.com/watch?v=SR6kEb4M ... annel_page
DieselBoost
New clutch arriwed. (Sachs racing bmw M5 240mm) with non-paddle type plate
DieselBoost
hello everybody.
project is on ice.
cause i have some health problems and i must relax now. :cry:
so lets hope il get my health back and i can do my dreams come true some day ;)
