removing power seats (need electricity) or manual override
the car is at the p and p so therefore, no power. I have to move the seat forward to get the bolts out. they will not let me in the pick and pull with a battery, but i have a 12 v cordless drill. would it have enough juice to move the seat? i would wire the drill battery to the right connectors with some alligator clips.
I know a booster pack would definitely work but those cost money and i don't have enough of that.
Bring the drill in, along with a 1/4" socket adapter and a 6" socket extension plus tool holder. Bolt that all up in the drill with a square bit or a torx bit (depends on the car). What you're going to do is use the drill to spin the motor that drives the seat rails backwards and forwards. It's a barrel shape socket on the front of a motor accessible from the front of the seats. It's on the inboard side on the driver's side and outboard on the passenger side.
THANK YOU!!derrith wrote:Bring the drill in, along with a 1/4" socket adapter and a 6" socket extension plus tool holder. Bolt that all up in the drill with a square bit or a torx bit (depends on the car). What you're going to do is use the drill to spin the motor that drives the seat rails backwards and forwards. It's a barrel shape socket on the front of a motor accessible from the front of the seats. It's on the inboard side on the driver's side and outboard on the passenger side.
that did not work
i went to the yard armed with drill, i was excited because it was 12.99 seat day but - no success.
the motors are mounted in such a way that there is no access to the front of them with a drill/socket/ext/etc. i even tried using the battery power to jumper the switches but no luck there either.
do i have to find a way to remove the motors to use this manual override???
