WTB 4 - 17x8 Naked T-Stars - FOUND THEM...Thanks!
eurowannabe
Post by eurowannabe »
They even have Falken RT615s, the same tire I'm currently running in auto-x. :alright:
Thank you,
So then you're looking for some wheels that ARE hub-centric to your car! The E39 wheels are hub-centric too, just not to your car. Hubcentricity means that the center bore of the wheel is an exact fit to the hub of the car, allowing the wheel to center itself on the hub with no axial play, hence the term hub-centric. All the rings do is take up the extra space that the larger hub bore on the E39 wheel has, thus making it hub-centric to your smaller E28 hub.
And you're also looking for wheels with an ET of 20 or over. Under 20 would produce non-desirable (or is it desirable) rubbing. Right?
DaRedRocket
Post by DaRedRocket »
Mine may be for sale soon. I'm assuming you don't want tires though? PM sent.
eurowannabe
wkohler wrote:And you're also looking for wheels with an ET of 20 or over. Under 20 would produce non-desirable (or is it desirable) rubbing. Right?
Chris, I've got 16x7.5 ET13s on the car now so no rubbing issues with low ET. Over ET20 and they'll rub up front, but not on the fender.
Kyle, sorry about my misuse of the word: "hub-centric". I knew what I meant as most others here did....even you, just didn't use the word correctly. My bad! :oops: I've had to use them before so I do know "what" they do and "why". ;)
1985bmw535i, I got the PM, but didn't expect one so soon. Please give me a week to get my SH!T together. I need to pick up a car in Monterey on Tuesday and will be back in AZ on Wednesday. Currently, my budget is smaller than your price. :(
