When I first installed it, it had a drone in the 2,000-2,200 rpm range, so I ordered an IE system. By the time the IE system got here, this system had "burned" itself in quite a bit, and the drone was almost gone. It has a deep burble at idle, and sounds kickass, excuse my French, at WOT. It probably only has about 100 miles on it, so it may burn itself in more with time, but there was still a slight drone in it when I removed it.
It comes with the stainless IE tips shown in the first picture, which will need to be welded on when it's installed. Your installer will also need to use a "Y" adapter just after the cat.
You can't see it in the first photo, but it's been cut in two pieces, which will make it much easier to ship. Upon installation, you just put a "sleeve" over that, and it'll be good to go.
$200 including shipping to the lower 48.
