Thank you for the info guys,i appreciate it!
My turbo is an T0384(from a sierra4x4), dunno if it is called "small" or "big" T3, i thought it was just a T3.
My hp target is 252hp(aka 745i turbo's hp) hopefully i hope i can achieve that with 0,4bar(5,9psi). From as far as i know the L-Jetronic(also called Motronic 1.0 right?) can handle boost up to 1 bar(15psi), but i am not sure if my fuel injectors(192cc) can handle the extra power(185->252).
My car does not have an "λ"(lamda) sensor so any ideas on how to check the air fuel ratio? Can i just attach a lamda sensor on my car and use it alone with an halmeter, and maybe any ideas on how to do this,like which wire goes where
I hope to get some more help from you guys, some more pictures over here:
