Thought I'd post a question the FirstFives dictator has - any info appreciated:
Posted by Peter Florance on January 07, 2008 at 18:45:46 from from 70.174.39.124
anyone know if the ID of e28 spring is larger or smaller than e12.
Do they have a similar part to e12 as far as top perch?
If the ID is a little larger but the hole pattern is still the same (I know it's at least rotated) it may work better for a rear spring pearch for 2.5" springs.
I suspect it is smaller but one can hope. I have some other options but I'm really lazy....
E12/E28 Springs ?
alotawatts
Answer
Looks like we have an answer from Mike:
Nope, both front and rear (E28) are a smaller diameter coil. The basic design for the upper mount is similar with the 3 stud mount, but I don't know about the bolt pattern.
Mike
Mike
on my shark the e12 springs were maybe 3 inches shorter then the e28 springs (but looked to be around the same diameter) i installed when i converted the rear suspension to e28 style, the upper mounts were the same 3 hole pattern but where the lower bolt goes into the trailing arm the e28 has a pilot that fits into the arm and takes the shearing force instead of the bolt, the e12 just bolts up flat against the boss on the arm
