17" - what size?
17" - what size?
I have an opportunity to pick up some 17" wheels for my lowered 535, was wondering what is the correct tire size for these would be if I have trimmed lips on the back. They belong to e39 originally.
Thanks.
Thanks.
What's the offset? That's going to play a big factor in your tire size.
I run 17x8.5s myself, but they're BBS RK which are quite light for a 17, I don't notice any ill effects in handling, as a matter of fact, the combination (rim and tire) weighs almost the same as a factory TRX or a 15" style 5 (which was mounted prior).
225/45R17 is the correct e28 tire size. A lot of people run 235/45R17 without issue, but overall circumference is a tad tall and throws off the speedo/odo by a bit. Both of these will likely require at least a little rolling or trimming on an e28 when used with typical e39/e34 17 inch wheels, but you might get lucky if you use the narrower tires.
My handling was improved upon switching (as far as cornering is concerned) to my style 19's. I was originally running the 235/45's, but felt they were unecessarily large being that the size was spec'd for the e39's heft/gearing. Never had any rubbing once I installed my mtechs, but I went to a 225/45 size anyway. I still want to try a 235/40 tire.
Jeremy, I know you were running style 5, what are your thoughts on 17" vs 16"?Jeremy wrote:225/45R17 is the correct e28 tire size. A lot of people run 235/45R17 without issue, but overall circumference is a tad tall and throws off the speedo/odo by a bit. Both of these will likely require at least a little rolling or trimming on an e28 when used with typical e39/e34 17 inch wheels, but you might get lucky if you use the narrower tires.
Thanks.
Jeremy is right, 235s are too tall. A lot of us run them because that was what was mounted on the style 5s when we bought 'emJeremy wrote:225/45R17 is the correct e28 tire size. A lot of people run 235/45R17 without issue, but overall circumference is a tad tall and throws off the speedo/odo by a bit. Both of these will likely require at least a little rolling or trimming on an e28 when used with typical e39/e34 17 inch wheels, but you might get lucky if you use the narrower tires.
And as Azure said offset makes it or breaks it.
These are both 17x8 et20 wheels but the one on the left is 235 and the one on the right is 225. No rubbing issues front or rear with rolled fenders.
The 4th from left is a 17x9 et24 with 255/40/17s, and it doesn’t rub at all with rolled fenders.
This is a 17x9 et20 with 255/40/17s and if a butterfly farts in Zimbabwe the tires will rub.
255/40/17 tires, et20 on the rear wheels. Rubs under hard acceleration. BAS springs and bilstein HD's
[img][img]http://i122.photobucket.com/albums/o272 ... ure014.jpg[/img][/img]
Modified fender lips?
Ricky535 wrote:255/40/17 tires, et20 on the rear wheels. Rubs under hard acceleration. BAS springs and bilstein HD's
