m20 turbocharged smog legal in CA
bavblue
Post by bavblue »
Anyone have turbocharged M20 in CA that is smog legal. I have 528 super eta and not sure about going with just i head conversion or do turbo as well. Anyone have experience with smogin turbo in ca.
I don't live there or anything, but if theres any sort of inspection you would be hosed right there. It could be tuned to pass with a catalytic converter, but I doubt the actual emissions would be your only hurdle.
From what I've learned, you need a CARB sticker, and the Dinan stuff seems to be the only stuff that's CARB legal, but I don't think they did anything for an M20.
You could buy a 524td shell, put your M20 in it and turbo it that way, since the td came with a turbo.
wkohler wrote:From what I've learned, you need a CARB sticker, and the Dinan stuff seems to be the only stuff that's CARB legal, but I don't think they did anything for an M20.
That would run way too clean for a 524td. I wonder if they would notice.
Then put some charcoal in the tailpipe?
90e34535i
Post by 90e34535i »
diesel's are exempt from the CARB every other year smog test.
ISO_524td
Post by ISO_524td »
I'm doing exactly this right now. Combining all the best parts of a 524td and 528e. Once I really get into it, I detail the project.
I first want to get the 524td running to see how the cylinder head is.....ie does it look as if combustion gases get into the coolant passages. Next, I want to get the 524td registered to make is smog exempt for as long as it's in California. Unfortunately, the bonehead who filled out the title released any interests on the front, but also put them as the lienholder to be recorded on the back, that I missed when looking at the title. I think this makes the title document void? Bonehead!
M635CSi
Post by M635CSi »
90e34535i wrote:diesel's are exempt from the CARB every other year smog test.
Yes but putting a gas engine in a car that was originally a diesel causes the car to no longer be a "diesel".
Luckily, a vehicle with diesel VIN is exempt as well. ;)
M635CSi
Post by M635CSi »
As long as it's diesel-powered, right? ;)
No. If you don't have to have it inspected, they don't need to know.
