What's the normal draw through fuses 5 and 6??
spinedocab
Post by spinedocab »
Key off, whaddya get through each of those fuses? I have a battery drain that I thought I had found, but maybe not...
So I am seeking comparison data or knowlege. Thanks,
Andrew.
Re: What's the normal draw through fuses 5 and 6??
Post by C.R. Krieger »
spinedocab wrote:Key off, whaddya get through each of those fuses? I have a battery drain that I thought I had found, but maybe not...
Andrew.
Way more than you want running through your tongue? :dunno:
spinedocab
And here I thought I was going to see a knowledgeable discourse from the great CRK. OhbeeBahbeeWellBeeBahBee.
uhhmn .035 amps drain measured between + terminal of the battery and the + cable
