Rear backing plate removal
I'd like to pull the rear backing plates and parking brake stuff front a pyp car, how do you get the backing plates off? Or I guess how do you get the rear hubs off?
About the only critical feature on the rear backing plates is the slotted holes for the E-brakeshoe mounting pins. I pulled a pin through its rusted out slot . My quick and dirty shade tree fix was to crush a 3/16 spring washer around it and put the brakes back together. 8 months later, its holding good as new.
