TCD Manifold Wastegate bolt size?
90e34535i
Post by 90e34535i »
I was wondering the specs on the bolts that hold the wastegate to the Manifold.
I just drilled my oil pan, should be tapping it in a little bit, hoping to start it for the first time tommorow or next day(with no exhaust YET).
Re: TCD Manifold Wastegate bolt size?
90e34535i wrote:I was wondering the specs on the bolts that hold the wastegate to the Manifold.
90e34535i
Post by 90e34535i »
Thanks Todd,
I got a tottally different question,
Are you using the stock Coolant Temp Sensor with your MS System?
I noticed my Coolant temp sensor has 3 wires, would you happen to know which of those I use?
thanks again,
russc
Post by russc »
90e34535i wrote:Thanks Todd,
thanks again,
Hu,
You sure. If your sig is right, any '90 M30b35 has a two wire temp sensor. Its the same sensor as the M30b34!
RussC
90e34535i
Post by 90e34535i »
Maybe im looking at a level sensor? Its screwed into the top of the radiator on the passenger side, Where should I be looking?
90e34535i wrote:Maybe im looking at a level sensor? Its screwed into the top of the radiator on the passenger side, Where should I be looking?
That's not the coolant temp sensor -- that's an aux fan switch, and it's on the cold side of the radiator to boot. The coolant temp sensor is on the thermostat housing.
90e34535i
Post by 90e34535i »
Alright, definitly makes sence, thanks alot!
