Turn signals/Washer fluid
ajs
Post by ajs »
Hi all,
I have a '86 524TD. In last few weeks my turn signals at first worked intermittently and then stopped working altogether. Does anyone know where are the relays located and how to check if they are working. Same with washer fluid.
Any ideas are appreciated.
AJ
Skeen
Post by Skeen »
Your best bet is probably to post this in the Tech Forum since it's not really 524td-specific--more people will see it there. Also, I would suggest looking for a Bentley manual too. Besides that, I would assume your relay's are under the hood on the driver's side fender well (at the fuse box). There's also something behind the driver's kick panel, but I can't remember exactly where. Hopefully others will chime in shortly.
ajs
Post by ajs »
Thanx, will do.
