I think I'll buy this
WSUCoug
Post by WSUCoug »
I just made an offer and it looks like the owner is going to accept.
In the words of Homer Simpson.......WOOOHOOOO!
Brian in TN
Post by Brian in TN »
mmmmmmm! doughnuts! (the kind you make in a car on pavement)
Looks good. First time Ive seen e46 wheels of that flavor on an e28. Not bad.
RoyW
Post by RoyW »
Looks awesome...love that red, and those wheels. What are the particulars on the car? Looks like CA or FL from the pic? Enjoy!!
WSUCoug
Post by WSUCoug »
It's an '87 535is. I'm driving a 528e now and I'm very much looking forward to the jump in power (again.....WOOOHOO!). The info below was from the owner's add.
"Engine rebuilt, new timing chain, all switches, sensors, fuel lines and pieces,
MAF sensor, fuel pump, water pump, thermo, Schrick cam (292 degree, I believe)
Rebuilt head, several new valves, new pistons, rings, oil pump, rod bearings,
K&N air filter etc. I have the paperwork. All engine work was done by
Cars and Concepts of Tampa. 1-99
It has a Contorti chip, though it's not installed. I took it out to troubleshoot
some idle problems last year and never got around to putting it back in. Idle problem
was simply a vacuum leak
Tie-rods, lower/upper control arms, centerlink, idler arm bushing, upper strut
bearings (all done by me) 6-2003.
Most of the window switches replaced, a couple of regulators, sunroof assembly
(some various hardware parts of it) have receipts 2-98
Rebuilt driveshaft, guibo, u-joints, limited slip rear diff. 1999. (don't have papers)
SI-board batteries replaced 1999, reset works fine. I have custom reset tool that I made that will
go with the car.
Fuel pump. 3-99 (have receipts)
Hood windshield washer lines and pump, hood foam replaced. 2-02 (have receipts)
Major service by BMW of MACON, also had them put in new waterpump and new rear
Bilstein HD struts. 3-02 (have receipt)
All body seals and trim (not bumpers) removed/replaced and body painted with SIKKENS paint
and clear coat by B&B Auto Body Works Inc. (Lakeland, FL) $2400. (have receipts) 2-98"
[QUOTE="Parts Pimp "]First time Ive seen e46 wheels of that flavor on an e28.[/QUOTE]
You ain't been payin' attention. I done posted pics of Ryan Rissler's 528 "ita" a number of times... :)
Jay in VA
Post by Jay in VA »
I have e46 wheels on my 533, just a different flavor.
