Plate light mounts
Mark40
Plate light mounts
Post by Mark40 »
I had some paint work done on the back of my car. I had to take the plate lights out and 2 of the mounts came apart upon removal. My car (an 88) had 4 little plastic slide in tabs that the screw went into. I tried to find new ones and all I could find are metal U clips. And they are not in stock anywhere affordable. Did E28's come with those or the plastic tabs?
Mark40
Re: Plate light mounts
Post by Mark40 »
Mark40
Post by Mark40 »
Aldo525
Post by Aldo525 »
Mark40 wrote: Jan 01, 2026 5:09 PM I had some paint work done on the back of my car. I had to take the plate lights out and 2 of the mounts came apart upon removal. My car (an 88) had 4 little plastic slide in tabs that the screw went into. I tried to find new ones and all I could find are metal U clips. And they are not in stock anywhere affordable. Did E28's come with those or the plastic tabs?
Plastic tabs are OE 63261378067. Still available.
https://www.fcpeuro.com/products/bmw-ex ... 3261378067
Mark40
Post by Mark40 »
Aldo525 wrote: Jan 01, 2026 6:48 PM
Well yeah, when you find the correct part number then they are easy to find. :)  Not sure how I missed that.
Thanks.
I believe my car (1986 M535i) uses the metal clips.  Did they switch to these plastic mounts later in production?
Aldo525
Post by Aldo525 »
stuartinmn wrote: Jan 02, 2026 12:34 PM I believe my car (1986 M535i) uses the metal clips.  Did they switch to these plastic mounts later in production?
My 83' 518i came with the metal clips and my 87' 525i use the plastic tabs. Both can be used in any year of production (same rear frame in the car) but the 83' was very rusty in the mounting place due to that metal clip....so replaced with the later sliding plastic tabs. I think plastic is better option to avoid the rust.
Mark40
Post by Mark40 »
I made up a batch of these using ABS. If anyone in the US needs a couple, send me $1 and I will drop some in the mail.
