Hi, we are converting an '82 528e from autobox to a manual. We don't know what we don't know but are looking for at least a pedal box. We are hoping to find a gearbox close to home - Westchester NY - and figure out what else we need, thanks for looking,
Chuck
WTB: auto to 5spd parts
Re: WTB: auto to 5spd parts
Here's a rough list of parts needed.
Transmission
Crossmember
Transmisson mounts
Flywheel
Flywheel bolts and plate
Back up light harness
Shift support
Shift Rod
Shift lever
Shifter coupling
Clutch pressure plate
Clutch disc
Clutch bolts
Pilot bearing
Pedals
Pedal bracket
Release lever
T/O bearing
Release pivot
Clutch master cylinder
Clutch Slave cylinder
Hydraulic hard line
Hydraulic rubber line
Rear mount for shifter support
Rear mount bracket
Insulator between shift support and body
Rubber boot under shift lever
Shift lever boot
Transmission
Crossmember
Transmisson mounts
Flywheel
Shift support
Shift Rod
Shift lever
Shifter coupling
Clutch disc
Clutch bolts
Pilot bearing
Pedals
Pedal bracket
Release lever
T/O bearing
Release pivot
Hydraulic hard line
Rear mount bracket
Shift lever boot
I have a rusty 84' 533i that I am slowly disassembling for parts. It is a manual and I don't need any of the transmission/drivetrain/shift parts and would be glad if they dound a new home. Car ran and shifted fine, just too far gone with the rust and I've replaced it with a new to me rust free E28. I am in Boston.
AndrewG wrote: Jun 18, 2025 11:34 AM I have a rusty 84' 533i that I am slowly disassembling for parts. It is a manual and I don't need any of the transmission/drivetrain/shift parts and would be glad if they dound a new home. Car ran and shifted fine, just too far gone with the rust and I've replaced it with a new to me rust free E28. I am in Boston.
This gearbox won't bolt into a 82 528e, different bellhousing configuration.
Good point. I hadn't bothered to check.
Thanks for the notes guys...and the help...good to know about the tranny, but would any of the other parts work? I assume some cross over?
Parts from 533i/535i that will work.
pedals
hard and soft lines
Shifter bracket that is attached to the car. This holds up the shifter plate.
the diff which should be a 3.25 instead of the 2.93 you have.
what bodes not work.
trans and parts on the trans
fly wheel
clutch
drive shaft
You can also use trans from 325i, but has to have the 2 side sensor holes. (Early 325i)
Andy
pedals
hard and soft lines
fly wheel
clutch
drive shaft
Andy
Thanks for the info Andy. Regards, Chuck
