Good evening, please check out my 535iS listed on Hagerty Marketplace. Some additional details not included in the listing are highlighted below.
1988 BMW 535iS For Sale: Hagerty Marketplace
1988 BMW 535iS 5-speed manual w/LSD
Diamantschwarz Metallic
199,050 miles
Maintenance
2025/198k: Battery replaced
2024/198k: In-tank fuel transfer pump replaced (Nick’s European Auto Repair)
2023/198k: Oil & filter, new battery, A/C recharged (One Way Automotive)
2021/196k: Clutch kit, pivot pin, fork lever, pilot bearing, rear engine seal replaced, new reference and speed sensors (Lubo’s Bavarian Motors)
2020/194k: Oil & filter, new fan clutch, fan blade, and radiator cap (Lubo’s Bavarian Motors)
2018/192k: Oil & filter, maintenance inspection (Lubo’s Bavarian Motors)
2017/185k: Rear wishbones replaced (Wolfgang’s)
2017/180k: Main & fuel pump relays replaced, A/C converted to R-134, driveshaft rebuilt (Bavarian Professionals)
2016/173k: Passed CA smog
2016/173k: New muffler and catalytic converter; valve adjustment and valve cover gasket; transmission, differential, and brake fluids changed; cooling system flushed; new thermostat and housing; power steering hoses and filter replaced; new fuel filter; front struts (Bilstein HD) replaced; new front upper and lower control arms, bushings, and tie rods; clutch assist spring, motor mounts, front brake pads and rotors replaced (Bavarian Professionals)
Known Issues
A/C doesn’t blow cold
Sun roof stopped working in summer 2023
Power mirrors have never worked
Passenger seat thigh bolster doesn’t operate
Front head rests don’t operate
Included
3 BMW keys (1 original, 2 uncut)
4 original BMW bottlecap wheels
Full trunk tool kit (minus blue BMW rag)
Original jack, wheel chalk, and spare tire
Bentley manual
Maintenance binder with records back to 1992
Covercraft sunscreen
Period correct BMW first-aid kit
Original 1987 BMW 5 Series dealer brochure
FS: 1988 535iS 5-speed w/LSD 199k
Re: FS: 1988 535iS 5-speed w/LSD 199k
Looks great... and nice write up too.
Thanks. Someone needs to buy this car before I change my mind about selling it.
Picked the car up from the shop today for an oil change, coolant exchange, and brake fluid change. Mechanic visually inspected the cooling system and found no leaks from the water pump and all coolant hoses are in good shape. I also snapped a bunch of pictures of the underside while they had it up on the lift. It looks pretty clean underneath. I can send pictures to any serious buyers.
Miles now show 199,088.
