ABS pulse generator connector help
gwb72tii
Post by gwb72tii »
The ABS connector on the wiring loom inside the engine bay is partially gone, as in dried out plastic cracked off gone.
I've replaced the pulse generator female connector with 1/2 of a 2 pin weatherproof connector. This was easy enough as the pulse generator has a red and black wires leading to the connector.
https://www.amazon.com/dp/B0D4ZM4H78?re ... asin_title
My question is the wiring loom connector has 2 red wires, not black and red wires. The OEM connectors only fit in a certain orientation (design of the connectors) but I now have no idea how to how to orient the other 1/2 of the weatherproof connector before I solder the leads together.
Any ideas how?
gadget73
Re: ABS pulse generator connector help
Post by gadget73 »
does it actually matter?  I'm not sure that ABS pickups are polarity sensitive.  If there is no color stripe or anything at all on the harness-side wiring to indicate a difference it seems to me maybe BMW didn't think it was overly critical either.
