Parts compatibility between tachometers
teh
Post by teh »
Hi everyone,
I have been looking for a tach that has a rev counter for my 525e for an awhile now. I have found a unit finally but it turned out it has a bad board (battery leak).
I was trying to fix it and broke the small pin that holds the needle for the speedo .... 😫
I know a lot of parts are not really interchangeable between the different iterations of the tachs. The unit with the rev counter that I want to use has 9 lights, the one in my car has 7. Is there any way I can use the speedo/odometer from the unit in my car and swap it into the other unit?
Thank you!
BillL
Re: Parts compatibility between tachometers
Post by BillL »
You should probably contact Ivo Christof in The Netherlands. He is an expert on these clusters. It depends, but my e28M5 uses a "code chip" plugged in the back of the cluster. Mine failed and the tach would not work. I got a new code chip from Lithuania via EBAY.
Good luck with your challenge.
