Bleeding steering gearbox... ?
Chicagotrader92
Post by Chicagotrader92 »
Not sure if this is a dumb question, but I will be swapping my leaking steering gearbox for a used (hopefully not leaking) steering gearbox in a couple of weeks. It seems pretty self-explanatory, especially since I'm replacing the tie rods, center link, idler arm, control arms, and end-links at the same time... AND installing coilovers. (It's going to be a long weekend.)
My only question is: Is there anything special I need to know about bleeding the new gearbox? Or will it essentially do it on its own as I reinstall the lines and refill the fluid?
kojo96
Re: Bleeding steering gearbox... ?
Post by kojo96 »
I'd at the least turn the pulley to prime the pump after getting fluid in it, before starting the car.
I think there's language in the manuals about turning lock to lock a few times. I'd do it at least a couple of times. But I've replaced a couple of steering boxes and don't recall any issues.
gadget73
Post by gadget73 »
I usually spin the pump by hand and keep adding fluid until it stops sucking it down, then start the engine.  Run it lock to lock a few times, top up as needed.
You can just start the engine but usually the reservoir level drops significantly and it might suck enough air to turn the fluid into a foamy mess. Takes a while for all that to fizz out.
any time I have a PS system open I use it as an excuse to drain as much fluid out as I can so it ends up all nice and clean. Takes a bit of pump turning to burp all that air out.
