Heater Control Valve (does this look good?)
Re: Heater Control Valve (does this look good?)
The washers seem correct. While you have it out, get a rebuild kit and replace the rubbers. Quite cheap and easy.
Thanks, I used the Uro kit. That's the rebuilt. The old rubber was in decent shape and the screen looked free of debris, but I replaced it all Anyway.
My 2 cents: the little rubber cone doesn't go there. Once the valve is disassembled, the cone should be slid down the rod against the circlip at the very bottom.
