should i be worried with pre detonation on partial throttle since the WOT map is only tuned? if i down shift and lets say i was around 4500 rpm would i be safe if the turbo was in boost. running 93 octane.
MSD 6AL
MSD 2step module
Tial 38mm wastegate 8 psi spring
He341 turbo
24# ford injectors
vortech fmu
TCD 059 timing chip
ngk pre gapped turbo plugs from miller
AEM wideband
Walbro 255lph
TCD chip
Re: TCD chip
There is one way to find out, go out and do your best to instigate the problem. If your exhaust isn't too loud you will hear the det if it is occurring.
I will say that I have significant confidence in a TCD chip. It should handle things as well as Motronic can be expected to handle them.
Re: TCD chip
turbodan wrote: Feb 11, 2025 12:01 PM There is one way to find out, go out and do your best to instigate the problem. If your exhaust isn't too loud you will hear the det if it is occurring.
Thank you will look for it. or try to hear it. it will be my first time running the chip. was asking around to see if anyone had problems with it just during regular driving.
