Flywheel reference sensor magnet
Notelect
Post by Notelect »
I am manual swapping my 528, posted about it before, and when researching the speed and reference sensors I noticed the flywheel needs a pin for the reference sensor to play off of. However I don't see that pin on my flywheel nor do I see it on the diagram for it on real OEM.
#8 is a dowel pin and there are three of them for the clutch to align. For manuals do the reference sensors play off of the dowel pins or am I missing something? Looking at pics of other flywheels I don't see anything save the dowels that the reference sensor could play off of
Notelect
Re: Flywheel reference sensor magnet
Post by Notelect »
Think I found I actually
Found this picture elsewhere
This is what it should look like on my flywheel, right?
Yes.
I'm not aware of a separate # being that it's an integral part of the flywheel and specific to each application.
Notelect
Post by Notelect »
1st 5er wrote: Dec 29, 2024 9:08 PM Yes.
I might try to weld on the piece from the flex plate from when it was an automatic.
Is there any specifics on how large the piece should be, or is there wiggle room? Piece I have is bigger than the piece welded on in the image above
BDKawey
Post by BDKawey »
for how archaic these efi systems are a few thou isnt going to make your engine explode. nail its location and make sure its welded good
gadget73
Post by gadget73 »
Whats it actually using the sensor for, just engine speed, or does it need an accurate timing reference for something? If its batch fire and not driving the ignition I'd assume its just speed. At that point its not super critical, just make sure its well attached. Don't want that thing flying off at 5 grand.
gadget73 wrote: Dec 31, 2024 9:43 AM Whats it actually using the sensor for, just engine speed, or does it need an accurate timing reference for something? If its batch fire and not driving the ignition I'd assume its just speed. At that point its not super critical, just make sure its well attached. Don't want that thing flying off at 5 grand.
The sensor is for ignition timing so it's got to be pretty close. However I don't know how much clearance there is between the tab and the sensor. I've always thought if I had one fail on a M/T car I'd try tapping a small hole and putting a small bolt in there. With red locktite. Never done it, but that's what I'd do.
Tone1633
Post by Tone1633 »
Does anyone have the correct position for the reference sensor block. I am in the same predicament and need to weld a tab on, but need the correct positioning. Either dimensions or a tracing..... Thanks
Tone1633 wrote: Jan 02, 2025 4:06 PM Does anyone have the correct position for the reference sensor block. I am in the same predicament and need to weld a tab on, but need the correct positioning. Either dimensions or a tracing..... Thanks
A/T or M/T?  I can probably measure it, but it might be a few days.  I measured one long ago for a guy in Australia, but gawd, that must have been 20 years ago and I doubt I can find the info anymore.  Ping me if I don't report in a few days, I'm not a flake but I am entirely capable of forgetting.
JohnH
Post by JohnH »
I went down this route when I fitted a manual gearbox to my 525e Auto. I used an E21 flywheel, but for the life of me icant find/remember how I worked the tab position out.
All I remember is thinking that the car was a bit gutless and the whole project was a waste of time.
I would highly recommend fitting motronic M1.3, which dosent use the flywheel tab, rather a timing wheel on the front of the engine. You will want to do this anyway when you fit a 731 head on it anyway.
Tone1633
Post by Tone1633 »
Thanks for the response, Mine is a manual...
Thanks
OK, took a reminder but I finally dug it out and took measurements and pictures.  The image a few posts up does look like what I remember, but not what I have, which I think came off an '82, E24.  But it was probably at least 15 years ago I pulled it so I might have the exact car wrong.  But it is a lightweight motronic flywheel.  Images didn't come out as clear as I would have liked, wow, like that's a first, but hopefully usable.  And I have the direction of the cutout by the tab facing in the wrong direction, look at the pic to be clear on that, not my scribbling.  And feel free to ask more questions.  Also, especially to the OP, don't forget the stiffener/spacer on the bolts and the bolts themselves are a different length than the ones on Autos.
Notelect
Post by Notelect »
Mike W." wrote: Jan 08, 2025 1:14 AM OK, took a reminder but I finally dug it out and took measurements and pictures.  The image a few posts up does look like what I remember, but not what I have, which I think came off an '82, E24.  But it was probably at least 15 years ago I pulled it so I might have the exact car wrong.  But it is a lightweight motronic flywheel.  Images didn't come out as clear as I would have liked, wow, like that's a first, but hopefully usable.  And I have the direction of the cutout by the tab facing in the wrong direction, look at the pic to be clear on that, not my scribbling.  And feel free to ask more questions.  Also, especially to the OP, don't forget the stiffener/spacer on the bolts and the bolts themselves are a different length than the ones on Autos.
Is the z location a specific place on the flywheel or can I weld the thing on anywhere on the side? I don't see how it would matter or it would tell when it's just spinning with the engine, and for all I know when mounting the flywheel all that matters is that the bolt holes line up, right?
Z is emphatically a specific location and the tab has to be pretty much exactly in the correct location.  Open this pic in a new tab to view it full size and you can see the Z marked on the side or the flywheel.  The dowel (kind of a sleeve which only fits in one bolthole on both the crankshaft and the flywheel)  locates the flywheel in the correct location on the crankshaft, so that's a fixed point, then you need the tab in the correct location so the ECU knows where to fire the ignition.  Say 1/8 of an inch wouldn't make much difference, but that's about as far off as you want, it's got to be pretty damn close to perfect.  Again, zoom in on the pic and you can see the mark and the Z.  Also the OT mark, but you don't really need it.
Notelect
Post by Notelect »
There is no notched line like that on my flywheel. Your flywheel is for an m20, correct?
Arggg.  No, M30.
Half you, half me.  I should have checked, 528's were mostly here in the US 528e's, but there are also a lot of gray market 528i's here.  Oh well.
Notelect
Post by Notelect »
Mike W." wrote: Jan 10, 2025 8:13 PM
Arggg.  No, M30.
No worries. You know any sources I can use to find out where to weld it? Or should I not chance it and just shell out the money for a new flywheel with one?
Tone1633
Post by Tone1633 »
I would like to thank Mike W for this info… I did not have this on my flywheel when I was getting my Euro 535 together and set the mark slightly before tdc on cylinder one.. the car ran fine, but always had a slight misfire at 1000 rpm and the stumble at 1800 rpm. I then re did it to the info Mike added to which I was approximately 90 degrees out and now the engine so far runs pretty darn sweet, no misfiring at all… thanks again.
Tone1633 wrote: Jan 18, 2025 3:25 PM I would like to thank Mike W for this info… I did not have this on my flywheel when I was getting my Euro 535 together and set the mark slightly before tdc on cylinder one.. the car ran fine, but always had a slight misfire at 1000 rpm and the stumble at 1800 rpm. I then re did it to the info Mike added to which I was approximately 90 degrees out and now the engine so far runs pretty darn sweet, no misfiring at all… thanks again.
Cool, it wasn't 2 hours for nothing then! That makes me feel better.
JohnH
Post by JohnH »
However, all 528i were LE-Jetronic, so didnt have a flywheel tab!
