Since there is such little info/photos of this setup online, I figured I'd make a post of what I sourced (+ photos of how it sits):
FRONT
→ Euro M5 BMW springs (7-17pt)** [31332225024]
→ US M5 BMW BOGE shocks (selected since the Euro BOGEs are NLA) [31311133517]
REAR
→ Euro M5 BMW springs [33531130723]
→ Euro M5 BMW BOGE shocks [33522225898]
I may be in the 1% of people to remove lowering springs, but for anyone who's frustrated with the compromise of aftermarket spring/shock setups and/or looking for an OEM solution, I highly recommend the setup above. I have about 3000mi on these, and it's extremely compliant, comfortable, and looks/feels like a brand new car (if it was 1988). Everything above was sourced through a combination of Schmiedmann, BluntTech, and, of course, Christopher Kohler. While this entire combination is not cheap, it is one of the best things I've ever done to the car.
Hopefully this is helpful!
*while this is not a perfect conversion given the US spec BOGE front shocks, this is as close as I was able to get (although I'm sure there are a pair of NOS Euro BOGEs out there...)
**I selected these for a slight drop opposed to the 18+ pt, but the ride height still measures 10-20mm higher than that of the BMW microfiche specifications. I also have a set of Euro M5 0-6pt springs that I likely won't install. They have the same free height so I assume the only difference is the rate here.
