Im seeking help with getting my turbo project going.
My Setup:
Megasquirt PNP2 ECU
Turbonetics 60/65 Turbo
deka 80lb fuel injectors
Stock Coil and dizzy cap
OEM Bosh crank sensor, ( I converted to Motorinc 1.3 with e34 stuff including harness)
Clutchmasters stage 3 clutch and stock flywheel.
I have a base tune loaded and some parameters set and am ready for a first start/drive but my throttle is reading full when there is no input. no response when attempting to calibrate it.
I have the 1.3 style 6 pin TPS unit installed. Any insight would be much appreciated.
First question I have is about the menu you have pulled up in that image. That would be the O2 sensor table calibration menu, the TPS calibration is done on a different menu. Under tools, should have one that says calibrate TPS. You tell it to read the current value with the throttle closed, then again at full throttle. Have you done this?
If it's still out of whack after doing that, you have either a wiring issue or a bad TPS. Wiring issue is likely.
I ended up tracing the brown/blue to pin 53 on my 1.3 harness. Brown black went to pin 52, 3rd wire = ground.
The top three wires for the switch (Blue, Brown, yellow) I traced to an unused connector inside the car. It is likely it was used for some type of throttle module on the e34 doner car. the problem is the top three wires are for the potentiometer side of the switch, which is what I need the MS to see. Not the bottom three which are for WOT and idol inputs.
So essentially I just flipped them so the ECU would see the potentiometer side of the switch.
What I did,
Brown/Blue - Blue = Signal
Brown/Black- Yellow = 5 volt
Brown/cream? - brown = ground.
