So now for what I have tested. As far as I can tell the bulbs are a dual filament, one for the indicator, and one for the running lights? As best I can tell they both work, the running lights and high beam switch on/ off with no problem. I tested the indicator filament by rotating the plug 90 degrees as shown below, connecting the wire meant for the running lights to the indicator prong, then just getting a wire to ground the prong on the headlight that is normally connected to the brown wire, and bingo bang bongo the light works (obviously steady no flashing) so I'm 99.9% sure the bulbs in the headlights are not the problem. I then checked all the bulbs in the rear lights and to the best of my knowledge they are functioning fine. I then "tested" the indicator relay under the steering column. It could hear it clicking when the indicator was on, I also got a random piece of trailer wiring, touched it to one of the prongs on the relay, while it was still plugged into the harness, and then touched it to one of the prongs of the headlights and then all four headlights on the front of the car started flashing ( this didn't really tell me much ). I still don't really know if the relay is working properly as I'm not sure how to test it, if someone could give me a link to a video/ article that would be great. As well as this I checked the voltage going to both indicators when the appropriate indicator was on and I would assume it to alternate between 0 and 12V a few times a second but it read a steady 0~0.1 V.
So as a conclusion I think that a wire is either pinched somewhere in the front end of the car between the headlights and relay in the steering column possibly causing it to ground out, or I think the relay isn't working. A couple things to note I took the front US bumper off the car as well as the side indicators, etc which is a total of 4 bulbs, this could hardly be the problem? And as well as that I also MAY have shorted something in the fuse box when working on the car while it was parked for the winter although I doubt this to be the case as the car still starts and runs and this indicator is the only wiring issue I'm aware of.
