For Sale: 1987 535i Turbo S50 project
Revox
Post by Revox »
I’m sure many of you have found yourself in this position... Big goals and aspirations, and lots of work done but along the way “life” happens. Yeah... it’s one of those. So here it is, my 1987 535i... with a transplant. I have swapped in an s50 with a turbo set up, s50 is fully refreshed (gaskets, bearings, timing components, etc.) Turbo set up is running a bar of boost. I have the car sitting on ground control coil overs, 540i m-sport brakes and some other tid bits. Currently. the s50 is set up on a VEMs stand-alone. The car itself needs cosmetic love, and the only thing needed to make the car run again is an ECU service, the current one has a blown ignition driver. I have a clean Kentucky title.
Info about the car:
1987 535i 237k miles odo is broken
S50 Turbo rebuilt <50 miles ago
M3 5sp 90k miles w/SSK
Ground Control/Koni coil-overs <50 miles
540i m-sport brakes (calipers, rotors, pads) <50 miles
PLX sm-pro with water temperature, oil pressure, AFM and boost sensor
4.10 LSD
RTA and Subframe is all poly
https://drive.google.com/drive/folders/ ... IaLvNppX0m
If something stands out to you shoot me a text, 859 797 4251
I would like to see the car stay together before parts come off, I would sell the entire car for $6500.
-- Added Mar 16, 2020 12:54 PM --
Price update $5500
Last bumped by Revox on Mar 16, 2020 1:55 PM.
