URO windshield weatherstripping fitment
Posted: Jan 03, 2020 4:02 PM
by Yojedi
I hope I am not rehashing old story but I am looking for comments on URO windshield weatherstripping fitment. In my search for replacement weatherstrippings for both front and rear windshields apparently URO offers a rear weatherstripping at 1/4 cost of a genuine BMW part. Would anyone care to chime in on its fitment?
Going the genuine BMW route is always my first choice. But at nearly $600 for both front and rear weatherstrippings warrants a look into alternatives. Are there still after market options for our nearly 30+ years old cars?
Re: URO windshield weatherstripping fitment
Posted: Jan 03, 2020 5:01 PM
by austin8753
Just like anything else made by URO Parts/APA, they are 110% garbage that will fail in a year or two.
Posted: Jan 03, 2020 11:23 PM
I put a URO windshield rubber in my E12, same part as E28, in 2008. When I sold it last spring it was as new and didn't leak a drop. Now the lockstrip shrunk considerably, I have no idea what brand, but the gasket itself held up fine.
Posted: Apr 09, 2025 5:50 PM
by URO Support
Hi guys, just saw this thread. We sell a surprising number of
Windshield Seal 51 31 1 822 185 annually, with no returns or defect reports. On Amazon the seal only has two reviews, but does have 5/5 stars. Same goes for
Rear Window Seal 51 31 1 820 485.
Hope that helps!
Posted: Apr 11, 2025 9:06 PM
by AdamCosmos
I’ve had one holding my rear glass in for around 5 years with no complaints. My installer did say something about adding some sort of non adhesive sealant to help prevent leaks, but it might not need it. Good luck!
Posted: Apr 12, 2025 12:33 AM
AdamCosmos wrote: Apr 11, 2025 9:06 PM
That sounds like standard BMW specs. The OE stuff is almost like putty, I always use a non hardening sealant and it's worked great.
DO NOT USE A POLYEURTHANE OR SILICONE SEALANT. Use the right stuff and it will seal just fine without gluing it in place. Seal it, don't glue it.
Posted: Apr 12, 2025 10:58 AM
by CanadianMiniFan
Do you have a specific brand of non hardening sealant you use? And do you use it glass to rubber, rubber to body or both? Thanks!
Posted: Apr 12, 2025 4:34 PM
CanadianMiniFan wrote: Apr 12, 2025 10:58 AM
3M 8509 Bedding and Glazing was my long time go to sealant, but it appears to no longer be available, at least here in the US. I recently used a CR Laurence product, for a slightly different application and it seems exactly the same as the good old 3M product. Even smells the same.
https://www.amazon.com/dp/B000KZWKE4?re ... asin_title
BMW specs between the body and the gasket, I use it both there and between the glass and the gasket. I've done a bunch over the years with no leakage problems. It's messy as hell, sticky, gooey, but works well, doesn't harden and seals. Use paint thinner for cleanup and expect a mess.
Posted: Apr 13, 2025 9:32 AM
by CanadianMiniFan
Thanks for the quick reply! Most of the British windshields I have done seal fine with no sealant and a similar seal and lock strip, but I always read about issues with e28 glass leaking, especially with aftermarket glass. Would rather just do it once and not have to get back in there if it does leak.
