Fixing temp gauge needle with later style SI cluster
Ju@n
Post by Ju@n »
Hi guys,
So a couple of months ago I plugged my cluster with the key in the acc position and that seemed to break my temp gauge.
I already had 2 more clusters with the same issue, particularly on all of mine, the temp gauge went to red-hot whenever the key was in the on position.
I didn't want to buy another cluster just for that, so I disassembled my cluster and went on to diagnose it a bit.
The temp gauge (and the fuel gauge almost equally) depend on the SI circuit. The SI circuit provides positive, negative and signal to the temp gauge (the fuel gauge uses positive and negative from the SI circuit or something similar, diagnosed this some time ago and memory is not my finest characteristic :laugh: ).
Ok, so, since I really couldn't care less about the SI part of the cluster (just as long as the lights go out when I turn it on), I decided I wanted to bypass those needed signals. On early clusters, with a separate SI board, it's much easier since it's modularized, on the later style clusters it's a single board with everything on it.
So on the next pictures I'll show which traces need to be cut and jumped:
Victim:
Disassembled:
Cut trace to positive on temp gauge:
Cut trace for temperature signal and bypass to gauge:
Now on the other side:
Desolder resistor and solder new jump wire for positive on fuel gauge:
Solder jump wire on positive terminal of fuel gauge:
Add jumper wire on negative terminal of temp gauge:
So with this modifications Fuel and Temp gauge will work regardless of SI circuit issues
Didn't modify tach nor fuel economy gauges since mine were working correctly, but similar mods will be needed if desired.
Hoping this fixes some clusters out there :D
Juan
RonW
Re: Fixing temp gauge needle with later style SI cluster
Post by RonW »
I've never seen a satellite battery board like that on the later style cluster. Whether they're NiCd or lithium, I've always seem them soldered directly to the board.
Before you started dismantling stuff, you tried disconnecting the temperature sensor and checking to make sure it wasn't shorted, right? That's the first thing I'd do if the needle pegged itself whenever I turned on the car.
Ju@n
Post by Ju@n »
RonW wrote:I've never seen a satellite battery board like that on the later style cluster. Whether they're NiCd or lithium, I've always seem them soldered directly to the board.
Yep, sure, tried that haha! I was begging it was something but the cluster, but tested pin 13 (IIRC) on C1 and signal was correct.
That satellite board is a fix by Programa I think, as I said, I have several extra clusters and only this one had that, The other boards I have have NiCD or Lithium batteries in "factory" locations
