Based on that, I decided to "design" a few options which I present to you below.
At first I was just going to install the Ireland Engineering cat-back system and be done. But the more I slept on it, I felt I could do better than their system, plus with their set-up you still have to decide to re-use your cat, install a new high flow cat or fabricate a new section if you're not going to run a cat . I would like to mention that IE's set-up has 1.75" O.D pipes, which I feel is on the small side for the M30, plus I did not like their heavy rear muffler, the caveat here is I do like their products and service and I am going to use their ceramic headers as pictured below to replace the stock cast manifolds. As an aside, the header downpipes are 2.0" O.D.
Side note - The stock exhaust with the cast iron manifolds weighs just over 100-lbs (!)
Another side note: I will be using stainless flex joints, all stainless pipe, and I will V-Band the exhaust no matter which setup I choose. I have $600 into this little science project..so not too bad.
Ok so onto the options I came up with, the stock exhaust is shown as a comparo below too, by the way I had lots of fun thinking about this and putting it together:
Option 1 Side Exit: Twin 2.0" O.D pipes into a single Magnaflow and exit in front of the rear right wheel.
Pros: Nice and short, fairly easy to fabricate, light, probably will sound cool, looks cool and good power.
Cons: Heat might damage the paint on the rocker and trim right above that.
Option 2 Full length: Twin 2.0" O.D pipes into a single Magnaflow and exit with a 2.5" pipe and twin tips in the stock location
Pros: Will sound cool, looks cool also and good power.
Cons: A bit more complicated to fabricate and heavier than the side exit option.
Option 3 Ireland Engineering Cat Back system: 1.75" O.D pipes into a resonator and long barrel muffler and exist with 2.0" tips in the stock location
Pros: Fairly easy to install and fabricate the section where the cat would normally be placed. Decently priced
Cons: Heaviest of the three options, maybe adds a little less power (smaller 1.75" pipes) than the above two?
What do y'all think?
Yasin
