This is the link to the eBay product I bought it was $12
https://m.ebay.com/itm/Universal-12V-Ca ... SwSzRZTtdJ
So, I took off the steering column exposed the ignition wiring.
The relay for the push button start has four wires:
Red Constant 12v+
Black Ground/earth
Two blue wires: One to Accessory and the other to start. Some also do ignition and start.
Then I popped out my cigarette lighter and mounted the push button in that position.
You still need to have your key turned into the last position and then press the button to start the car.
I will post pictures soon.
Constant 12V+ Red Ignition Switch Harness
Starter Black Ignition Switch Harness
Ignition Green Ignition Switch Harness
Accessory. Purple Ignition Switch Harness
Tach Black Coil
Brake Switch Green/Red Brake Switch
Parking Lights Gray/Black L Gray/White R at Light Switch
Hood Pin n/a
Factory Disarm n/a
Door Trigger Brown/Purple (-) Passenger's Pin Switch
Door Lock Yellow/Blue (-) Driver's Kick Panel
Door Unlock Green/Blue (-)
Horn Wire Brown/Yellow (-) Steering Column
Untitled
Untitled
