The rear end started to get pretty splashy feeling so I parked it. in addition, I have an exhaust leak and it's pretty noisy. First I am going to tend to the rear suspension/subframe, then mess with the exhaust.
The parts smorgy for the rear end "refresh"
1. Transmission Filter
2. Output Shaft (CV boot) "rebuild" kits.
3. Rear Wheel Bearings. (SKF)
4. Dog bones (Lemforder)
5. Trailing Arm Bushings (Lemforder)
6. Subframe Bushing Bolts (BMW)
8. Subframe Bushing Nuts (BMW)
9. Trailing arm Bushing Bolts and nuts (BMW)
10. Subframe Bushings (FEBI).
The Plan (such as it is):
1. Pull the OutPut Shafts.
2. Remove the Brake disks, calipers, ABS lines, Brake fluid lines, plug/tie off.
3. Remove the Trailing Arms. Not having done this before and not having read about the dust shield removal/wheel bearings I will "mumble" past this and do some research.
4. Take the Trailing arms to a machinist to press out the old bushings and press in the new.
5. Maybe take the trailing arms to get powder coated. Maybe I will paint them myself. I certainly don't know jack about this decision. Seems like Powder coating is reasonably priced, but not sure it is necessary.
6. Change out the Subframe Bushings. I have the "$300" tool.
7. Maybe pull the subframe and get it powder coated. Maybe not. If it's not that involved maybe I will give it a go.
8. Clean up the Diff. It's pretty crusty, or appears pretty crusty to me.
Put it all back together and test drive it. Pics below of what it looks like now.
Left Side Dog Bone is pretty thrashed.
[/url]Driver Side boot, see split at the left:
[/url]Greasy Diff:
Right Side Subframe Bushing and equally thrashed Dog Bone.
[/url]
[/url]
[/url]
[/url]
[/url]
[/url]
