Tool Review: Harbor Freight electric DA
Pneumatic DAs are so sweet, crank up the compressor and buzz along at 10K OPM or whatever speed. But they're absolutely air pigs, unless you have at least a 5HP commercial compressor you'll spend a lot more time waiting for pressure to build than you will sanding. So I bought this a couple of years ago and love it. It's not perfect, it's not as fast as a pneumatic tool, seat of the pants says it's about 2/3 as fast, it's kind of heavy and not nearly as smooth in your hand, but hit the switch and go and go until you're done. It's freakin' great. It's a bit of a beast weight wise, but lean into it with both hands and it'll drop a little but not much and just keep going. Comes with a hook and loop backing pad which I swapped out for a PSA one. It's probably not a pro grade tool, but I'm not a pro and it suits me just fine. Somewhere between cheap and expensive, a little over $50 with the ever present 20% off coupon. 4, maybe 4.5 stars out of 5 because it is heavy and vibe prone, but it's still a kick ass tool. So far I've used it more on wood than metal, but it doesn't care, hit the pedal and go.
Re: Tool Review: Harbor Freight electric DA
Now we know you've REALLY been drinking.
John SCB
Post by John SCB »
cek wrote:Now we know you've REALLY been drinking.
:rofl: :rofl: :rofl:
dsw99a
Post by dsw99a »
thanks for that unsolicitated plug. Ill need one soon when i start on the body of my e12. I just killed my compressor sandblasting some rims for my f-150. I can start on my body as soon as i get a FEW more bit and pieces from a good friend of mine.
jhh925
Post by jhh925 »
Seeing a Harbor Freight tool review here reminds me to throw out an unsolicited plug for this Youtuber, a Canadian who goes by AvE.
He's often hilarious, and his tool reviews can be genuinely useful. Unlike most reviews, his evaluations are mostly tear-downs of the tools to evaluate construction, materials, components, etc. He's also has a series of videos where he built, used and revised a hydraulic torque testing device that he used to test a bunch of breaker bars and ratchets to failure.
"Keep your dick on the ice."
mescko
Post by mescko »
Fo-cus you FUCK!
jhh925
Post by jhh925 »
That's the guy. Someone even went to the effort to do a wiki site just to decode his vocabulary.
EventuallyAyrton
Location: Wherever the E28 happens to be parked- Morrisville, NY
Post by EventuallyAyrton »
At least there are other people who watch him
Prizm
Post by Prizm »
I have used for years, works good untell you drop, and the switch stops working or you break the body. I would put a hook and loop pad on it so you can switch back and forth as needed.
