If you've ever tried to clean them even with just water they probably look like this
I'd be glad to pay 20-$30 for some fresh paint, and I'm positive a bunch of people would also.
I'd spend that on the M5. I'd live with it on the other cars.wkohler wrote:Still available for about $100 ea.
davintosh wrote:I'm not a screen printer now, but have been in the past, and have thought of that possibility as well, but it would be difficult for a printer to do this inexpensively. Screen printing isn't exactly rocket surgery though, and on a hobby scale the printing part wouldn't be difficult to do; lots of stuff on YouTube about DIY screen printing. The tough part I think would be getting alignment just right on those small buttons.
I think a better bet would be to figure out how to make either slip-on or dry transfer decals, like the kind you'd use on a model car. I'm not sure what the usual process is for creating them, but I do know you can buy inkjet-printable decal sheets. The only trouble then is finding an inkjet printer that will print white, which right now is a trick only done by the pricey high-volume commercial machines. If you could find a small poster printing shop that has one of those printers you might be able to work with them to get the job done.
http://www.amazon.com/Papilio-Inkjet-Cl ... 005D5H0L4/
https://www.epson.com/cgi-bin/Store/jsp ... 0/FandB.do
Decals aren't exactly stickers; usually it's a super thin film that basically carries the ink and provides some protection and adhesion to whatever you attach it to. With the slip-on decals, you usually have to wet the film first to get it to separate from the backing, then it just slips off of the carrier and onto the switch (or whatever you're putting it on. With the dry transfer decals, after the image is printed, the ink is peeled off with a carrier film, aligned on the switch, then you rub to transfer the ink & carrier film to the switch.86GT635 wrote:Solid post man, thanks.
I'm thinking it was done by screen printing originally. Even though it doesn't last, I think most here would prefer it over stickers.
I don't know much about screen printing so forgive me for any inaccuracies in my thought process/questions.
Is it possible to digitally scan a good condition switch assembly and have that transferred/printed to the printing screen? Or is it all cut out manually?
If a jig was made to keep the switches in the same position, accuracy could be spot on if a bunch of switches were done at once.
That's what I'm wondering, if we as a community would like to have a screen printer do a hundred switches in one day, we could probably find somebody to do it, and the price per piece would go down. Kind of like a group buy/service.
You must still be sober because you used the italic command properly.oldskool wrote:I can do it. My dad is a T.V. repairman and has an awesome set of tools.
